Service Bulletin #6924
I've got an airbag failure light on with a code 46 (drivers seat belt) tripping the light. Does anyone have a copy of the service bulletin # 6924 that gives instructions of replacing the wiring harnesses under the seats?
Totally off topic JFP in PA (and Rabbitt1445)and I apologize in advance....but your signature line should have an "a" instead of "de"...
"Accrochez-vous bien a vos reves"....."hold on tight to your dreams" (plural) In the ELO song of the same name, the lyrics read: "Accroches-toi a ton reve"....which is the singular version. ....just passing this on to you FYI!
Alex '80 911SC Targa '06 997 C4S Coupe - SOLD '07 997TT Coupe |
Bien entendue!....Accrochons-nous a nos reves!
This forum is awesome. I always learn new things.
My 99 Boxster Base falls after the VIN production change (628xx). I have the airbag light and fault 45 (drivers side buckle). Buckle measured 133ohm buckled/399 unbuckled. Is the buckle bad and/ or do I still need the harness retrofit kit? TIA!
The answer is probably a yes.
Airbag light fault 45
I am having this issue with both buckles. I am the second owner purchased in 2012 with 19,000 miles. (986 base produced before TSB 6924. When I took the seats out I discovered the harness on the car side had been altered and that there are two grounding posts on both sides of the car, each with one ground wire. Do you have two ground posts per side? When I was putting the seats back in I noticed that after putting the connectors back together there seemed to be a tiny amount of play between them so I secured them together with wire ties hoping that would solve the problem. I made it 35 miles before the airbag light came on again. I would like to do the ohms test on the seatbelt buckles before I go ahead and replace them. Thank you for your time and if I come across any new information or possible remedies I will pass them along. |
