Exotic Vehicles are here
1-ev.com's Avatar
Will this jack hold Engine and Tranny together?
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 08-10-2013, 09:41 AM
Nick at Pelican Parts's Avatar
The thumbnail you shared is too smal for me to make out the detail of the jack.
I use a hydraulic motorcycle / ATV jack to lower engine and transmissions together. Works great and has a nice flat long top sections to balance the engine on. I also strap the engine to jack when doing this to help prevent it from falling off.
- Nick
1-ev.com's Avatar
Sorry Nick here is the better pics of the jack that i am talking about, here specs said 450 lb http://www.harborfreight.com/450-lb-capacity-transmission-jack-39178.html
+ '68 911
Old 08-10-2013, 10:18 AM
83 911 Production Cab #10
JJ 911SC's Avatar
No...
My 550 table could not do it but the 660 does.
450 would not even do the engine alone.
Who Will Live... Will See
Old 08-10-2013, 10:57 AM
Uncertifiable!!!
Uwon's Avatar
I may be wrong but my guess is that the motor and trani weigh well over 450 lbs which is max rating for HF jack. I also would worry about the lateral strength of this jack. Could it twist under max load and collapse?
Nick has a well proven solution. Then you have guys like me..... See post #31 through 36 in
http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst-2.html
Note that the motor sits on a wooden platform to minimize the chance to dent the heat exchangers.
The jack that I use I got from Costco. 2 ton or so with a wide seat and 20 inch max lift, I think.
Hope this helps. Good luck.
Cheers....
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-11-2013, 06:46 PM
Engine is a little over 400lbs & manual trans is about 130lbs. so figure 450lbs minimum for the combo.
Old 08-12-2013, 08:58 AM
