997S Clutch Kits
Suspect my 06 will need new clutch kit soon. Is the OEM Sachs kit a good replacement? Also, should the flywheel be replaced as well? I have noticed some vibration in the shifter when off the throttle slowing down.
How many miles does it have? The sachs kit should last about as long as the original did. Its hard to put a mileage on how long they last because it just depends on the driver and the type of driving, so just assume it will last about as long as your first one. there is a procedure for checking the amount of play in the flywheel but 95% of the time they do not get replaced.
