Insert Tag Line HERE.....
rattlsnak's Avatar
Low compression.
I posted this in the boxster forum as well.
Hey, I'm a early 911 guy but a friend with a '99 boxster was having a problem with running rough and a compression test showed all three cylinders on the right bank ( passenger side ) were @ 30 lbs. I pulled the motor out today and am getting ready to do a leak down check but is there any common problems or anything in particular I should look for first? I was thinking head gasket maybe, but all three cylinders is unusual. I pulled the valve cover off and everything looks fine. All the fluids were fine with no coolant in the oil. Any ideas?
Old 10-15-2013, 01:49 PM
These engines rarely blow head gaskets. Cracked componets are more common.
Old 10-15-2013, 01:54 PM
