NYC
Engine # Decipher
I am not sure if I copied the numbers correctly. Does any body have a chart that tells me what this engine is? M96/0466101301
2000-2001 3.4L 996 engine.
NYC
It is not a factory reman, as those contain an "AT" in the sequence, but it could be a third party replacement.
NYC
Yes your probably right some one other than Porsche installed it however it is one of the best running engines I have heard in a while. No leaks hardly any chain ramp noise on start up when it's cold and good cam deviation readings. No chunks of metal in the pan or oil filter. Very slight engine misfire due to a cracked coil housing.Thanks for the info.
