Which IMS update kit?
I am doing research on the IMS update kit for a 2004 996 Porsche my friend just bought. I was not aware that there are multiple choices out there from stock, to slightly beefier bearing, to custom oil-fed bearing system.
What do most people go for? And the overall procedure is? 1. Drop the gear box (it is a Tip in this case) 2. Lock the cams in place 3. Access the cover plate 4. Remove the bearing with special tool 5. Install new one 6. Replace cover plate 7. Undo cam locks 8. Check timing 9. Install gear box.
oil fed system is the best
Insert Tag Line HERE.....
oil fed is by far the best but is also the most $$$.
I am not sure that much money is warranted. Something better than stock, but not quite an arm and a leg is fine. So, a beefier bearing kit?
For a dd I would rx the LN bearing or the Pelican upgraded seal bearing.
There are two variety of oil fed bearings as well.
The one from LN is a plain bearing - which requires a fairly significant teardown I believe. The other system retains the normal IMS bearing setup - albeit with the seal removed - and replaces the stock bearing flange with an oil fed system. It looked pretty slick to me. Here's the link (no affiliation): DIRECT OIL FEED (DOF) FOR IMS BEARINGS | TuneRS Motorsports
Going faster all the time
The 996 is a joy to work on, but this is pretty critical stuff. And it is warrantied if done by an approved shop (mine was).
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
this is what i did: LN install
1. Drop the gear box (was a Tip in my case) locked at TDC on front pulley 3. Access the cover plate 4. Remove the bearing with special tool 5. Install new one 6. Replace cover plate change diff fluid, never will be easier 9. Install gear box. have fun with starter removal/install and the TC bolts
why did you take the starter off?
Only way to get at the torque converter bolts..........
Out Of Control
Go to Flat 6 innovations Jake Raby is the master of the Porsche engine and the solutions for their problems. He will be able to give you names of approved shops to install which ever solution you choose as long as it's one of his or LN Engineering.
DOF by TunerRS
