Troll Hunter
997 Metzger Coolant fitting Problem?
Went to a DE this weekend where a GT3 lost his coolant hose/fitting on the straight and spun/had to get towed. I was told these Metzger's have an issue with the fitting that tends to blow, and that there is a 'class action suit' out there somewhere because it happens so much.
This is a new topic to me…sorry I usually spend my time over on the air cooled section. Can anybody point me in the right direction? Thanks Nick 997 Twin Turbo 2009
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
So how to fix it? Some use the Shark Works approach and either drill and tap, or pin the fittings to keep them in place: Others have had a professional welder permanently fix the issue: ![]() Both seem to work, but the welding seems to be the better of the two. Now the bad news: The engine has to come out of the car to do this either way.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 01-20-2014 at 09:56 AM.. |
Troll Hunter
Gotcha…is there a recall on this or one being considered? Geez this seems like a nasty issue to have dangling over our heads….
Thanks (BTW, Roebling Road is a cool track)
No recall to my knowledge............
It's a major topic over on Rennlist. The 04 GT3 I just got has the coolant pipes welded. I believe it's an engine out process.
Coolant Line Failures- NHTSA - Rennlist Discussion Forums Jim |
