Stripped cv joint bolts
I have four hex bolts with stripped heads on my axle/cv joints where they connect at the wheels. Any suggestions on a solution? there must be a bolt removal tool that is made for this problem.
Old 01-20-2014, 01:12 PM
pors1968's Avatar
You can use a good pair vise grip.
Old 01-20-2014, 01:15 PM
LakeCleElum's Avatar
Heat, as in oxy/acel torch + Kroil (or PB Blaster) + vice grips.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-20-2014, 02:04 PM
Home of the Whopper
You may be able to clean out the bolts and insert the driver deeper into the head. Use a mallet to sink it in good.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-20-2014, 02:36 PM
French Import
zippy_gg's Avatar
BFH and a cold chisel. Make a slot so the chisel will catch and try loosening by hitting with the BFH at an angle going counterclockwise of course.
I had to this for at least 2 bolts on each side.
Gilles
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2015 BMW K1600 GTL, 2011 BMW X3, 2016 BMW 435i hard top convertible
Old 01-20-2014, 02:40 PM
Grappler
Rodsrsr's Avatar
If all else fails you can cut the heads off with a grinder.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-20-2014, 02:52 PM
vice grips work great so long as the brakes are on.
'90C4
Old 01-20-2014, 03:24 PM
206 637 4071
Old 01-20-2014, 04:10 PM
My thread with the same dilemma...
http://forums.pelicanparts.com/porsche-911-technical-forum/626404-stripped-10mm-cv-joint-bolt-question.html
I ended up cutting it off with the heavier dremel cutting wheel.
Good luck
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 01-20-2014, 05:03 PM
John Walkers tool works amazing for this , I think sears has a version
Old 01-20-2014, 05:34 PM
Charles Freeborn's Avatar
The cold chisel method takes considerable practice and has unpleasant consequences if not done properly. Also difficult to do in tight spaces. I practiced for years on stripped out philips head case screws on Hondas.
Use the tool John illustrated.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 01-20-2014, 05:41 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I end up cut the head of the bolt flush with the CV joint, remove the CV and use a pair of vice grip to take it out.
Who Will Live... Will See
Old 01-20-2014, 06:05 PM
Thanks to a quick search and the infinite wisdom of John Walker, 4 stripped cv bolts were out in no time. Thanks John . Tim
Old 08-24-2015, 08:24 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Care to share the model number and where you bought the kit?
Henry
Old 08-25-2015, 05:51 PM
From lowes
Not recommended to use with impact. For cv bolts the 1/2 inch/13 mm worked great, tapped on with rubber mallet and had all 4 stripped bolts out in 5 minutes. Good luck, Tim
Old 08-25-2015, 06:36 PM
shoulda used the right tool in the first place. Tripple square 8mm if im not mistaken. cant use a torx bit
Old 08-25-2015, 06:52 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Nope, allen wrench. Six sided. Simple as that.
The only triple square I am aware of is for the door frame striker plate. I do believe it is 8mm.
OP did not state year of car. If is is a newer 911, 964 and forward, I can't comment. Wish my 81 had triple square but it does not. I just replaced all of them a few years back. Hex ports were getting tired and I am sure me and PO ham handing things was the problem.
I have the Irwin extractors. They are great but the bite can wear out over time on frequently used ones - i.e., 10mm size.
1981 911SC Targa
Old 08-25-2015, 07:07 PM
FYI Dude, I just bought the car and the damage was already done. Thank you for the insight though. Typical comment from a "self proclaimed genius" Tim
Old 08-25-2015, 07:10 PM
Bob Kontak's Avatar
Give him a Mulligan. He is most probably pissed off about something else. It can happen.
1981 911SC Targa
Old 08-25-2015, 07:37 PM
El Duderino
tirwin's Avatar
I fully endorse Irwin tools.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-25-2015, 07:43 PM
