Are these H5s wired correctly
After years of driving with the high beams on ( aimed down) trying to troubleshoot the very dim low beams on 89 3.2 started with the headlight relay kit no change all other electrics work as they should. pulled out the H5s and discovered a possible discrepancy with the wires going to the plug. The Bentley diagram for 89 shows the brown wire in the middle of the plug. The socket on the car is wired with the low beam in the middle and brown ( ground) on one side and high beam in correct position. Is this correct?
Old 01-21-2014, 09:26 PM
Bye, Bye.
Scooter's Avatar
This is the diagram that I use for my '87. Not sure if it is the same for '89:
Elvis has left the building.
Old 01-21-2014, 09:32 PM
Maybe someone out there with the same year has some pics of the factory headlight socket
Old 01-21-2014, 10:03 PM
