midnight911's Avatar
Heater backdate blower works only at 1 and 2
The car is 1984 carrera with manual heat control.
The heater blower (footwell) only works at position 1 and 2. Nada at position 3.
Looking at this diagram i stole from a thread, seems the footwell blower is getting power from the relay in the front trunk when the knob is at the position 3? So, i should say the relay in the trunk is broken?
The blower works when the knob is at positions 1 and 2.
Please help me interpret this diagram.
thanks in advance for the help.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 01-23-2014, 07:30 PM
it also helps if someone told me which pin at the heater control feeds power/ circuit when the knob is at position 3, so that I can check if the control has issues.
1998 E36 M3 4dr
2004 Lexus GX470
Old 01-23-2014, 07:41 PM
aj88cab's Avatar
As you noted, FWB speed setting #3 runs thru a separate relay and fuse. the relay is on the front (trunk) relay panel, round relay closest to the windshield I think. The fuse for speed #3 is also on the front fuse panel, fuse #2 (25A). Check the relay & fuse. If the rest of the speeds work this is probably where the problem is.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 01-24-2014, 04:27 AM
wwest's Avatar
Power for speeds 1 & 2 comes from pin 4 of the heat control module back in the engine compartment. Speed 3 comes from the front trunk relay AND fuse....
Since you are getting power from the heat control module for lower speeds that module is working CORRECTLY.
Old 01-24-2014, 08:52 AM
very helpful and thank you.
yes, it was the relay. i swapped with another...the ac one as ac is not present...and got the position #3 working.
thanks again!
1998 E36 M3 4dr
2004 Lexus GX470
Old 01-24-2014, 06:20 PM
