French Import
While I have the tank out I'd like to get it cleaned inside and out.
I can handle the "out" part but not sure about the "inside". The fuel level tube is now out; I don't have, yet, the big Allen (21mm I think) key to remove the bottom filter. There was apparent signs of leaks nor fuel smell. I've read about "boiling" and POR15 inside treatment, but not sure if this is needed. Any input appreciated. TIA.
Gilles Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2015 BMW K1600 GTL, 2011 BMW X3, 2016 BMW 435i hard top convertible Last edited by zippy_gg; 01-24-2014 at 08:19 AM.. |
No need for a big allen, here is the tool I use. The bottom of a 13/16 Craftsman spark plug socket.
Chris '75 911s Targa |
I am restoring my fuel tank too and have read a lot of mixed opinions on different sealants and cleaning methods (mostly regarding the degradation of any plastic swirl pot). I've decided to play it safe and give it a thorough cleaning with POR15's "Marine Clean" product, together with a good pressure washer rinse. I think the right treatment depends on the state of your specific tank.
What are you planning for the exterior? I was thinking of POR15 followed by undercoating (although I learned you really need to use a primer in between for the undercoating to adhere to the POR15). |
Here is another fuel tank cleaning thread that may help:
http://forums.pelicanparts.com/porsche-911-technical-forum/741968-engine-died-out-fuel.html
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
French Import
Gilles Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2015 BMW K1600 GTL, 2011 BMW X3, 2016 BMW 435i hard top convertible |
French Import
Still not sure what to do with the interior; I already washed with water and liquid soap, and then rinsed with more water. Although I had the tank filled with water twice there are still some very strong fuel fumes... I'll use some compressed air later this afternoon and see if it makes a difference.
Don't use any coatings inside the gas tanks after 1973.5, it can peel off the whirl pot and clogg the lines.
http://forums.pelicanparts.com/porsche-911-technical-forum/768320-cis-gas-tank.html
Ed 1973.5 T |
Fuel tank drain plug tool
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler Previously owned and rebuilt: 60's VW Bugs, Buses & Ghias |
Lots of snow Porsche away
I pulled my tank and after a lot of reading decided to try to clean it via the electrolosys method, and I was absolutely stunned at the results. I just pulled the filter and reistalled the plug, filled the tank basically full with warm water mixed with baking soda. Dropped a steel pipe in with a piece of rubber hose to isulate the bottom and guidline tape to insulate at the tank opening where the rod leaned against the side, hooked up a 12v battery charger at the 6 amp setting (pretty sure it was negative on the steel rod positive on the tank but check that cause it is really important lol) and fire on the juice. Over about 15 min it ran from a 6 Amp draw down to about a 1/2 amp, unhook the power pull the now fully rusted steel rod out, brush clean it to steel and change the water, do it again. Did that about 4 times before it stopped dropping current and when I rinsed it out, it looked like galvanized steel inside, dull but totally clean. Remarkable, and so low on effort it is totally my style of cleaning lol.
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
And no more crap in the filters or carbs through the full summer. So I know it was beyond visual!
Another good solution, i just did mine a couple of weeks ago
Get about 4 or 5 litres of Apple cider vinegar, (normal cider vinegar works also i assume) Swish it around n the tank every few minutes then after about half an hour empty it out and do it again if needed. mine was pretty bad, so much that i cut a access hole so i could give it a good scrub, but i found out about the cider vinegar too late, it literally rinses the rust away i couldnt believe it.! I painted tank bay and tank with Rustoleum Rubber spray, after a zinc primer, its good cos it dampens vibration in the tank as well as keeping rust away ![]() ![]()
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
What if your car's tank has gas in it while other things are being done i.e. engine out and car going to body shop for some refinishing. Could be atleast another 6mos before driving again. I've already added Sta-bil but with today's crappy gas you really can't be too sure. Is there something else i should do while my car is not being used? I'm more concerned about the deterioration from ethanol than anything else.
Mike '89 CARRERA #402 |
This is how I cleaned the interior of my tank. I wouldn't coat the interior with anything because it will probably flake off at some point in the future and I would not have it boiled at a radiator shop if you have a plastic swirl pot.. it will melt.
http://forums.pelicanparts.com/porsche-911-technical-forum/661056-cleaning-fuel-tank-without-damaging-plastic-swirl-pot.html
1976 911 Targa 2.7 CIS Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior 1963 356 SC- crashed ![]() 1962 356 C- sold ![]() 1965- 912- sold- fun but too slow Last edited by matt gineo; 01-25-2014 at 06:12 AM.. |
Is there a noticeable advantage/ difference using a rubber spray rather than just por-15 and por-15 paint?
