Throw Out Levers
I am trying to eliminate the Omega Spring on a couple of 915 Transmissions being used on a 911SC and it seem to be an idea to use the earlier throw out arms but I am unsure which one to use.
Item 5 in the above drawing is 915.116.713.01
Item 7 in the above drawing is 915.116.713.05
Both look as if they may work.
Has anyone tried either of these or had any other experience.
Thanks in advance for any advice
Old 01-27-2014, 07:06 AM
I think they all will work, but somewhat depends on your exhaust system. The straight pull system ( catches the trunion at the end of the arm) will fit with old style heat exchangers or headers. The angled arm will fit with the later styled heat exchangers ( I think they started with the 1975 911s), and uses a different clutch cable that bends around the end of the arm and attaches/adjusts at the middle stub along the arm.
Old 01-27-2014, 07:19 AM
clutch arms
#7 drops enough to run with the cross over piping.
In the picture its the one in the middle.
The one on the top is a 930 part number where #7 is a 915 part #
Bruce
Old 01-27-2014, 09:16 AM
