Taking it apart is easy
Is my transmission falling off? There are no dumb questions. . .
While doing random maintenance, I noticed that there are gaps at the top of the rubber transmission mounts, where they meet the car's 'body'. I checked the torque on the mount bolts and they were good. I thought the bolts might be too long, so I removed one of the bolts and it shows no sign of bottoming out. I replaced it and torqued to 58 ft-lbs.
I notice that both the engine mounts, as well as the transmission mounts seem to indicate a slight forward tilt to the engine/transmission unit, which I imagine could be explained by the trans mount being too low for some reason. Is what I'm seeing here normal? If not, what's wrong? The mounts are 2 or 3 years old.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
I guess the $50k question is are you getting any movement? Put a jack under the
cross brace and check. Good luck, Dave |
Isn't there supposed to be a heavy thick washer in there?
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Have you checked this? From the '78-83 PET KATALOG:
The left assembly is from a Turbo, the right one from an SC.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Jerome,
I agree it looks "funny" but I believe it is normal. I noticed mine looked the same when I put my engine/tranny back in a couple of weeks ago. I have sport mounts that are about a couple of years old. I eased my mind when I confirmed the shift rod is centered in the chassis hole. If the tranny was sagging by an inch as your picture suggests the rod would be off-center causing the shift coupler to touch the bottom of the tunnel. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
El Duderino
Ok... Following up with my own dumb question. From the picture above, if there is no contact between the bracket (part 1A) and the chassis above through the mount then why do people debate the differences in transmission mount stiffness? If that rubber isn't coming into contact with anything then it's not dampening any vibration, right? Maybe there is more going on that I'm not seeing...
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
The rubber is molded to a metal center tube that is clamped hard to the chassis with the main mounting screw. The outer body of the mount is secured to the cross-member. The rubber provides lateral and vertical play of the transition and isolated vibrations to the chassis. The transmission will twist slightly due to the rotational moment from the engine.
Some replace the rubber mounts with full-metal versions to improve shift precision at the expense of more chassis vibration. Ingo
Spiderman
Normal, you're tightening on the metal sleeve same as the rear motor mounts. Rubber is between that sleeve and the outer which attaches to the body or tranny mount. Have to push up on the motor to see if the rubber is worn, not likely in 3 years.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
@Jerome: these mounts are worn and tired. change.
no sir. SC is same as left in the PET-grafik. Right grafik is earlier models, a sort of one-part-bridge. here's my 79 SC (FIN-PET-check reveals exact parts as in grafik below) ![]()
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 01-28-2014 at 07:10 AM.. |
83 911 Production Cab #10
Yes...
![]() 1: SC 1A: Turbo
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Schleprock
Correct. There are four large washers used on the trans mounts and four on the engine mounts. Each mount has a big dished washer above and below the mount.
Kevin L '86 Carrera "Larry" |
only 87-89 G50 carreras had a top washer. lets see a shot of the bottom. post #9 shows the clearance between the washer and the mount with new rubber. when they get old and saggy, the washer gets a lot closer to the mount. same with engine mounts.
Schleprock
Interesting on the washer count. '83 and '86 PET pdf diagrams say 4 washers for the engine suspension, 4 washers for the transmission suspension.
I have four on my '79 (not even remotely stock), four on my '87 and have seen four on pretty much every other one i've serviced. Probably a dozen in our local circle of friends cars. Weird.
Here's a shot of the bottom as best as I could do. Although the rubber is squished thinner on one side, it doesn't look too bad, does it?
![]() This is a shot of the topside of the engine mount. Same age as the trans mounts, about three years.
This is a bump.
I posted the pictures above, as requested. Possibly it is clear enough that there is a forward slope in the engine/transmission unit, because the rubber in both the engine and transmission mounts is squeezed narrower in the front edge, which I suspect indicates the forward/downward slope I mention. How this relates to my original question is something I would like to understand before I spring for a set of new mounts - which might just mask some problem.
Member 911 Anonymous
If it bothers you, you can always shave down the metal sleeve about 5-6 MM so the rubber can contact the mounts.
My fanatic track buddy and others did this to their 3.2's. I cannot say if this will improve anything but they seem to think so. I can see how it will reduce slop or twist and allow a more precise shift on turns. But to answer OP, No it is not falling out.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
that does seem like a lot of squishing. you can get the factory cabrio/sport mounts which are stiffer. the all metal ones are good for track cars but I wouldn't put them on a street car.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Is your top washer upside down?
Having the concave side up on the engine mount is the position recommended by smart people on this forum (could one of them have been Grady Clay?), whereas concave faces the rubber on the transmission, according to the same recommendation. There is discussion on this point.
The PET for my car is not clear as to position of that washer.
