Removing the Vent Trim Bezel
How are you able to remove the switch from the vent trim without removing the bezel that has the light markings on the 996? Secondly, how do you remove this bezel? Mine appears stuck :
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Remove all of the bezel screws. The switch knob is removed first, using a pick to release the spring. Once the knob is off, remove the nut for the knob, then lever out the bezel using a plastic prying tool.
Instructions are here: - Nick |
