IMS association to cam Timing
Will a degrading IMS always (or almost always) show a deviation in cam timing?
From Pelican Tech article: "You can compare the deviations in the timing between the two camshafts to see if they vary widely, particularly when revving the engine (see Figure 18). Sometimes a failing IMS bearing will also trigger a “check engine light” warning on your dash, as the car's computer realizes that there is a significant deviation between the two camshaft readings." Thanks Ed
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
The best way to check for failing IMS bearing is to take oil samples and send them off for testing and cut the oil filter element open & spread it out looking for metal particles. You should also remove the oil sump plate after draining the oil & look for metal filings in the remaining oil on the plate. You must also look for bits of plastic in the filter media & in the sump plate. This indicates chain rail wear & will cause cam deviation issues. Last but not least, when the sump plate is removed look up inside the pickup tube at the screen for debris. Most important is quit using Mobil one in these cars. Motul 8100Xcess or Jake Gibbs oil only & 5000 mile max intervals.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
