Does this sound like IMS failure
Is this IMS failure
After diagnosing I changed all plugs but 4,5,6 were pretty bad, coils are new switched them anyways cleaned MAF, didnt touch camshaft the car still misfires / stalls makes loud / swiiissh noises etc will a bad camshaft sensor make such serious noises?
Sounds like a IMS bearing that has a failed cage. Is this a dual row bearing car? 2000 or earlier?
You can hear the spinning when you shut it off. Don't run the car. Tow the car to the shop. Hope the ims shaft hasn't snapped. To me it sounds like the bearing is letting go and it's loose on the race.
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD", 2001 Polar Silver 996 twin Turbo |
Misfires will be caused by you cam chain tensioner failing. Make sure the readings are in spec. Also the primary o2 sensors will cause the car to misfire bad
A bad ims will just create engine noise I believe. I don think it would cause misfires and fouled plugs. |
Check for the camshaft deviations too. It should be no more than 6 or 7 I believe. Anything more may be signs of IMS problems.
Hello, my name is Mike! 2001 Porsche 986 Boxster S 2004 Porsche 996 Carrera |
OK I changed the Camshaft with a after market camshaft of ebay - it looked different i still tried it out - it started a little better then before but still camshaft error code
when I unplugged the Camshaft sensor altogether it wouldnt even start also the swish / screeching sound is the pulley I ordered the OEM camshaft to make 100% sure. Now, lets say the new sensor is OK and i still get the Camshaft error code same bank what would that mean? I checked with Camshaft deviation 1 using PIWIS usb Cable and it was on 0 crk But I dont see and option for camshaft deviation 2 is that normal?? thanks Last edited by jassmix; 06-21-2014 at 08:54 PM.. |
