275/35/18 read tires?
Would there be any problem going to 275/35/16 tires instead of the stock 265/35/18"
If I did this, I would leave the stock 225/40/18 on the front. The reason I am considering this is because I found a deal on that size. I currently have one bad tire on the back. The 275 tires are the same brand and model. |
I believe the factory size on the facelifted Carerra uses a 285/30/18. You "should" be okay running 265/35/18 pending your car is not lowered.
I may be wrong. Hopefully someone with more experience can chime in.
Hello, my name is Mike! 2001 Porsche 986 Boxster S 2004 Porsche 996 Carrera |
16"?? Buy a new tire. Assuming you have a 996 Porsche 275-18 should be fine if you have a C2.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 06-19-2014 at 02:03 PM.. |
Yes, it is a C2. I had to replace one rear tire last year so it only has about 1/3 the wear of the bad one. The tires I have are $185 each and I can get a new pair of the 275s for $250. How much will the size difference affect the speedometer? It reads 4mph high right now. |
you don't specify what brand of tire. Bridgestone RE-11 have a 0.3" difference in diameter between 265 & 275.
Going faster all the time
I run 265 in the rear on mine... as I found the tire I liked and it was an amazing deal. I have run it without issue for the past 2 years. All four came as a matched set (with corresponding smaller fronts). The biggest issue (aside from raw clearance of which you shouldn't be concerned) is the diameter. Try to get these as close as possible to not upset the ABS system.
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
On my C 4 I ran 285/30/18 225/40/18 and fit super well.
had 265/35/18 before , prefer wider, and they are Contis.
84 911 Carrera SOLD not forgotten 01 911 C4 factory Aerokit ![]() 76 914 rust bucket SOLD !! 03 Boxster S sold 98 944 S2 G Red,sold 04 FRC red Vette |
