bcheney's Avatar
996 Repair Estimate
Ok just lookin for a ballbark estimate on the following:
1999 996 with 80K miles on the clock. #1 cylinder is leaking coolant after dash warning light came on. Engine was shut down and no internal failures apparent as there is no oil/water transfer evident...(no milkshake). If you check the heads, replace headgaskets, do the rear main seal and install LN Bearing fix what should this all cost? I'm sure there must be a few folks who can chime in!
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 07-02-2014, 05:58 AM
The only part I can speak to is the LN bearing replacement. I got a quote of $3000 from a reputable Porsche indy for that and to change the RMS while he was at it. That was on a 2002 996 a couple of years ago. Good luck.
Mike
Old 07-02-2014, 06:47 AM
I rather doubt you will get away with "check the heads, replace head gaskets" to repair a coolant leak in one of these engines. You need to be aware that these engines never blow head gaskets, so the coolant leak more likely involves a cracked head.
Old 07-02-2014, 08:57 AM
KNS KNS is online now
Yep, most likely a cracked head. There are places repairing them.
Kurt
Old 07-02-2014, 11:10 AM
External leak? Can you get a Pic? There are other components that can leak:
AOS is one
Old 07-02-2014, 03:14 PM
Cracked head or crack cylinder? I though that the early 996 crack cylinders.
Robert
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD",
2001 Polar Silver 996 twin Turbo
Old 07-04-2014, 04:50 PM
Robert
Definitely a possibility with the 3.4L engines.
Old 07-05-2014, 09:34 AM
Speculation is useless. Get it to someone you trust. Tear it down and figure it out. Then you will know what is right for you.
Old 07-05-2014, 05:50 PM
bcheney's Avatar
996 engine
Thanks for all the replies guys.
08 Cayenne V6
75 914-6 Conversion
Old 07-05-2014, 08:17 PM
