hello, i'm new
, I just buy a 996 c2 year 2000 aero kit, 84.000km . I just change the oil on my 996. and I have checked the status of the oil filter.... there are a few small fragments of metal : ![]() links pictures : do you think that? IMS BEARING failure ??? many thanks for your responses stef |
It could be, it might not be. I would suggest dropping the oil pan and seeing how much metal there is. Install an IMS kit.
I'd hate to say it but....quite possibly you're heading there.
![]() ![]() I found this pic of a filter prior to IMS failure....I'm no expert but it might be worthwhile doing the IMS upgrade at this time....imo! Good luck!
Alex '80 911SC Targa '06 997 C4S Coupe - SOLD '07 997TT Coupe |
If the metal is not ferrous, it is probably just normal wear, but I would do another oil change in about 1K miles to see what was happening.
thanks you
the little pieces are not magnetic, it looks like the aluminum... I'll drive 2000 km and and I will remove the oil filter for a new control... then following your tips, I will update the IMS. I'll keep you informed ![]() sorry for my bad English.... stef |
+1 what JFP suggested. 3 little pieces of non-magnetic metal are likely nothing to worry about, but keep checking to be sure. You could also send your oïl off for an analysis to somewhere like Blackstone labs.
"Once ferrous starts showing up it's too late for a rebuild". REALLY????
That's not what I have read. In fact, that's the whole point of the "guardian system", is to detect ferrous metal before an IMS failure. That's why you crack open your filter to check for metal each time you do an oil change. JFP - on what basis would you say that a few metal flecks in his filter and this guy needs and entire engine rebuild? What are you a Porsche dealer or something? I would say IMS for sure, but WHOLE MOTOR REBUILD??? C'mon...
1970 911 T 2004 Carrera 4S |
When the IMS starts to go, it spreads a fine ferrous grit everywhere in the engine, which starts grinding away like an abrasive compound. Unfortunately, the way the M96 engine case and oil system is designed, there are endless places where this grit can accumulate, only to reappear in the oil later and start the grinding process all over again, eventually destroying every bearing surface in the engine. This problem is exacerbated by the bypass filtering system used on the M96, which allows this stuff to circulate around the oil filter media. This is why both LN Engineering and Jake Raby have remained adamant that once this ferrous grit starts to appear, you should not even consider retrofitting the IMS, as the ferrous grit will also destroy the ceramic replacement IMS bearing as well. While small amounts of alloy flakes will show up from time to time in these engines, they are neither harmful or necessarily dangerous to other engine components. But once the ferrous grit starts to appear in any quantity, the only known way to get all of it out is to disassemble the engine and clean it in an ultrasonic cleaning bath designed for the purpose. It only takes one bit of ferrous grit to reduce a $20K engine to a boat anchor.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 07-28-2014 at 02:39 AM.. |
How much ferrous grit is an issue? I ran a magnet over every crease in the filter and got this.
I would call that problematic. That much ferrous metal would disqualify the car for an IMS retrofit.
50% of Porsche trained techs! |
So yes, I am officially older than dirt, and the OP is looking at a real problem................
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 04-20-2021 at 02:56 PM.. |
Options?
Drop the sump cover and see what you really have; if there is a lot more of the same, your engine has a problem that is not going to get better.
