XLR8'd Member
David 84 911's Avatar
Clutch due ?
How do you know if your clutch is getting worn and can it be adjusted. Goes into gear a little harder than before. Thanks.
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 09-14-2014, 05:02 PM
I take it this is for the '02 996? Can you start with some basic info about the car...mileage, service history... When was the last time the clutch was bled? I'd probably start there and see how it feels. What about trans fluid? The fluid is critical to smooth operation and not any trans fluid will work. If you do the clutch the trans will be out and that's the perfect time to put in Porsche trans fluid.
Depending on how the clutch is used, it could last from 40 to 80,000 miles. If it's the original clutch it is 12 years old and may have worn down to the rivets. The fingers on the pressure plates also get weaker with use, causing the clutch to not let the trans shift properly. So if you decide to service the clutch, get an entire kit with TO bearing as well. These clutches are not adjustable BTW.
Tony G
10 Porsches come & gone!
1962 Morgan Plus 4
Old 09-15-2014, 04:34 AM
ltcjmramos's Avatar
A test that has stood the test of (my) time, if the car shudders when you're in Reverse, idling back easily, time to change it.
Jumpin' Joe
HWFMR Minister of Offensive Driving (Retired)
'12 Carrera GTS
'11 BMW 335d (People Hauler)
'12 VW Jetta Sportwagen TDI (Dog Hauler)
Old 09-15-2014, 12:03 PM
Mine has almost 100k, if it wasn't changed when it had a new motor put in at~ 35k. No issues so far. Used to be a 50k job but now I've heard of ones going to 150k.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 09-20-2014, 12:02 PM
XLR8'd Member
Thanks gents and sorry for the delay in responding.
Bought at 42K KM (+/- 30K miles) and now has 88K KM (+/- 50K miles).
Never been changed from what I know.
Going for tranny oil soon (thanks Tony).
Jumpin' Joe: Will try that.
Old 10-08-2014, 05:20 PM
