Guest
Posts: n/a
Comments: I have the same problem as Allen from Dec 1 2013 above I installed a new vent valve to solve hard starting. I have the same sensor hanging by 2 wires and now can not fill with fuel. Where does the sensor go, will that solve the problem?
September 28, 2014 Followup from the Pelican Staff: Can you share a photo of the sensor or can you identify it from our tech article and point it out to me? - Nick at Pelican Parts See the attached photo. ![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: |
GREAT! Thanks for sharing the photo. There is a small black plastic molded piece that is fitted to the filler neck. That magnetic switch pops into that black piece. It should be obvious that it fits inside of it. WITHOUT it installed, you will have the issue you are experiencing.
- Nick |
