1999 C4 AOS Quetions
Could the oil and water mix in my engine actually be caused by a bad AOS unit ?
One tech article mentions disconnecting the coolant pipes and hooking them together to by-pass the AOS as a test Anybody have any additional info. on this procedure ? Are there coolant pipes (hoses) connected to the AOS I am not sure that I see them in the diagrams of the AOS Need some sage advise on this one thanks |
Before even thinking about trying to by-pass the coolant lines, you need to know that even getting at the AOS on a 996 can be a bear, so if you think it is leaking, just change it out rather than try to jury rig a by-pass. It can be done with the engine in the car (http://www.renntech.org/forums/tutorials/article/238-air-oil-separator-replacement-aos/), but it is easier and quicker to drop the engine if you have the facilities. That said, judging by your other thread about the oil cooler, you may have to seriously consider that you have a cracked head, which is more common than and AOS intermix.
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 12-06-2014 at 05:54 AM.. |
Wishing, Hoping, Planning, Dreaming etc... Dusty Springfield was on your side. Maybe it is the AOS.
Let me put it this way...
Has anybody had an oil and water mix problem and it DID turn out to be the AOS ?? |
Yes, about 1% of the time, the rest were mostly cracked heads.
Check this thread:
http://forums.pelicanparts.com/porsche-996-997-991-forum/841557-1999-c4-oil-cooler.html Post #2 in the other thread that you started about this has a link where it did turn out to be the AOS.
Yes i had this problem it mix water in oil it was the AOS
Sent from my iPhone using Tapatalk |
