2006 gen 1 997 coolant sys pressure
can someone help me with what the expansion tank cap is rated for pressure wise...and also, what pressure does the coolant system normally run at...?
I need to check system pressure after replacing a water pump, thermostat & several hoses and before i add coolant...I dont want to over pressurize the system to check for leaks... thx, bob
I live for 911 tweaks... |
thx jfp...so i guess to test the system I should pump up the system to no more than 20 psi and watch for the needle to drop = losing pressure = have a leak...
how long should i wait to see if their is a leak...? 10-20 min's enough...? thx again... :-)
We wait a minimum of 15 min., prefer 30 min.
thx again jfp...u have helped me on other 996/997 q's & I appreciate your help... :-)
Happy holidays...bob
