oil pressure gauge
Pegged at 5 from "key on to key off". Sender at fault? Gauge at fault? Anyone have this problem? Procedure to remedy?. Any help or advice appreciated. Thanks guys
Old 12-24-2014, 10:22 AM
Most likely the sender is shorted.
Old 12-24-2014, 10:46 AM
Unplug the sender, you don't need to take the nuts off. Just pull the spade connectors off, and see what the gauge does.
Old 12-24-2014, 08:47 PM
Thanks guys.
Old 12-25-2014, 07:29 AM
Easy Fix
Bought a new sender, installed it today. Can be done from the engine bay or through
the wheel well opening (easiest with a hoist). Looks daunting at first, but isn't. Pics follow. Only took 20 minutes including building wrench. Gauge works as it should now.,
Old 01-23-2015, 10:24 AM
