Front Differential Oil Change - 2003 C4S
I changed the gear oil in my manual transmission last week with the intention of changing the front differential gear oil. Once I got a look at the front differential I was unable to determine where the fill plug in the drain plug is. There are forums here that talk about 997 and turbos but I cannot find anything in detail on the 996 C4S. If anybody could help with some detail that would be appreciated.
Completely covered, with photos, in the Bentley 996 manual, starting on page 39-8.
Thanks for the response - I am a newbie and don't have that manual - any quick suggestions - transmission was easy - I'm only going to do basic stuff myself - so I prob won't buy the manual - thanks
Should be straight forward. Always keep the car leveled when filling the trans or diff to ensure you have the correct amount
Gearbox was easy, but I cannot find or determine where/what are the fill and drain plugs for the front differential - I was hoping someone could just describe and/or show a photo. Thanks
GAFB
Drain plug is at the back of the diff, pretty much in plain sight. Fill plug is harder to find; it is next to the right/passenger side output flange, oriented toward the front of the diff and car. See photo. I just did this job yesterday, took almost 2 bottles of fluid. Note - output flange not pictured. I removed both my flanges to replace the seals.
17mm wrench for both plugs.
Several BMWs |
Thanks so much for the help - I rea appreciate it. Sorry it took a while for me to get a response back.
