Recurring eng Check Light
Keep getting 1126, low fuel pressure/vacuum leak/failed H2O sensor bank 2
and 1133, H2O sensor bank 1 and 2 sensor1 . Anything definitive here to continue troubleshooting or is it time for new H2O sensors. |
Year and model of the car would be helpful.
Recurring eng check lt
2001 911 carerra
I suspect you have a vacuum leak. Check the intake and breather pipes for leaks.
Another possibility is a faulty AOS. Try pulling off the oil cap with the engine running, if it is very tight/hard to remove, it is most likely faulty. |
