Engine leak question
Hi Just purchased a 2000 996 Cabrio (C2) from a very unscrupulous dealer in cocoa fl. (Extreme Motorcars).
One of the many issues I was not informed about is when the 996 is warm there is an oil smell and upon inspection oil smoke can be seen exiting the drivers side rear wheel well. There is no noticeable oil leaking when the engine is not running, not a drop. Being new to the boxter engine my "guess" is a leaky valve cover dripping on the header, do that sound reasonable? How difficult a job? if not, any other ideas of what else it could be? Thanks for your help! Rick.
1980 928 S Euro 1987 928 S4 1986 944 N/A 2001 Boxster S 2000 996 Cabrio |
Buildwerks LLC
Hello Rick,
Hopefully it is not your valve cover, as that would be a major repair. Look to see if there is a leak by the spark plug coils. 9 times out of 10 the spark plug tubes will be the culprit. Very easy to change and inexpensive, look it up in the forum. Fernando
Fernando Lopez Buildwerks LLC Tampa Bay / Sarasota Area 1957 356A Coupe |
