996 wheel sensor connection part number
1998 996 RoW C2 coupe
My ABS light and TC Off light came on yesterday. This was quickly followed by my speedo reading very erradically. I checked for error codes and found a problem with the rear left speed sensor. Upon further inspection and a little trouble shooting, the speed sensor is OK but the connector that the speed sensor and the brake wear sensor plug into is cracked. That is causing a short in the connection. I really have two questions.
1. Is there a part number for this specific cable?
2. Is it possible to replace this cable somewhat easily?
On the electrical diagram (sheet 10) you can see the cable goes from the wheel housing to location X2/4 which is into a white 30 pin plug. This should be located in the rear left footwell. Does anyone know exactly where this is? Is it under the rear drivers side seat?
Any help that anyone can give would be most appreciated!
Old 05-09-2015, 06:48 PM
