whm (guest)
Guest
Posts: n/a
I have 06 c2 is it possible to change the plugs without the removal of the headers and muffler? thanks
Old 05-11-2015, 10:04 AM
Yes definitely, requires a bit more patience and a good selection of different length extensions with wobble capability to get the job done on the passenger side of the car especially for cyls 4 and 5. I say go for it. I like to use a 3 inch wobbly extension, a stubby 1 inch extension, a spark plug socket and a 12" long ratchet with wobbly head. Using the separate extensions will allow you to remove the stubby once you get the plug far enough out to grab the 3" extension...otherwise it will hang up on the muffler bracket...Removing the rear wheels also really helps provide access.
- Casey
Mitch Leland's Avatar
And it really helps if the car is on a lift...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-09-2015, 11:46 PM
These tools help make it somewhat easier.
kd service kit 41740
Sears.com
Kobalt 24 piece metric tool kit.
Shop Kobalt Metric Mechanic's Tool Set (24-Piece) at Lowes.com
Old 06-10-2015, 10:33 AM
