Dave L. (guest)
Guest
Posts: n/a
I have a 2001 911 carrera 996 convertible..
when the top is up it rattles when roads are rough.
It there a way to adjust it?
Old 05-11-2015, 10:19 AM
Those cars do rattle, the first step is to find the source of the rattle. If it is at the windshield frame you can try to tighten the clearances by adding felt to the areas that rattle. Usually the seal that seals the top against the windshield collapses, and then the rattles begin. It is probably best to replace the seal and then see if you still have a rattle. The adjustment shouldn't go out once it is adjusted. Chances are something is worn and should be replaced.
- Casey
