Guest
Posts: n/a
My 2006 c2 has some white smoke on start up,but nothing after. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Make sure your car is not overfilled with engine oil. Could be the air oil separator. Take a look at your intake and if it is seeping engine oil, that is another sign that your AOS could be failing. Of course the definitive test is to check the crankcase vacuum on cold start. Should be pretty solid at 5" of water.
- Casey |
