Secondary air system
Have replaced the secondary air pump on my 2002 996 cabriolet and have encountered fault codes 80 secondary-air system bank 1 and 208 secondary-air system bank 2. Any suggestions?
Old 08-05-2015, 04:26 AM
I had that problem after pulling the engine to do the bearing a few months ago. A couple vacuum lines in the back (front?) cracked during the process but weren't obvious.
TC
Old 08-07-2015, 10:43 AM
Check your vacuum supply. The lines, canister, one way valve and switch over valves. Is it a tiptrontic? If co check the coolant shut off valve on the trans.
Rob
Old 08-09-2015, 08:10 PM
