Horn Problem
ihave a 1999 - 996. when making right turns the horn blows, just started doing this. the other day while parked, not running, not locked you could touch the car and the horn blew.
i removed the streeing wheel, checked out the horn wires, everyting looked good.
i had to remove the horn fuse in order to drive with the horn going off.
Any suggestions?
thanks
Old 08-10-2015, 04:06 AM
Replace your airbag retainer to steering wheel.
Rob
Old 08-10-2015, 03:15 PM
Yep. Or you can fiddke with some spacers. Best is retainer for around $80,iirc.
Old 08-11-2015, 03:06 AM
Thanks.....
Old 08-11-2015, 10:52 AM
03 C4S, horn stops working when I hit a speed bump. Hit the speed bump again and it works normally. Air bag retainer issue as well?
Old 11-27-2017, 03:46 PM
Airbag
Get a new airbag retainer from Porsche and have a qualified technician install it
Rob
Old 11-28-2017, 08:04 AM
Montychristo128's Avatar
I fixed mine with some rubber grommets, was fairly simple once I managed to get the airbag off!!
Objects in the mirror should just go faster............
996.1 Forest Green C2, Subaru Forester XT (not broken)
Gone: Ford Sierra Cosworth (Tarmac Rally Spec), Ford Escort Mk2 (Tarmac Rally Spec),Triumph TR6, Fiat Mirafiori Sport,
MGB GT, Mk 1 Golf GTi
Old 12-13-2017, 07:08 PM
NYC
Purchase # 30 rubber o rings at Home Depot that will do the trick. I repaired my vehicle using them.
Old 12-26-2017, 05:57 PM
