BBi Autosport Porsche 997.1 GT3RS StreetCup Arctic Silver/Black
![]() ![]() ![]() Greetings Pelican Forum Members, We would like to present this clean 2007 Porsche 997.1 GT3RS belongs to our good friend and Pelican forum member Spyerx. Don't let it's pristine looks fool you into thinking that it is a garage queen. Built and maintained by BBi Autosport, this 997 GT3RS is a formidable weekend track warrior that has logged many hours at various race tracks throughout the West including Circuit of the Americas. Keeping it purely functional, this 997 GT3RS weekend track warrior is outfitted with BBS E88 wheels and our complete BBi StreetCup Exhaust, Roll Bar, and Suspension Package. All BBi Autosport products are now available directly through Pelican Parts and we are definitely proud to have established this great partnership! Vehicle Specifications 2007 Porsche 997.1 GT3RS Arctic Silver Engine Porsche Motorsport Cup Headers BBi 997 GT3 Street Cup Side Muffler Delete BBI 997 GT3 Titanium Tips BBi Billet Coolant Pipe Fittings Welded Transmission Porsche 997 GT3RS 4.0 Light Weight Flywheel Clutch Kit Porsche Motorsport Cup Shifter Porsche Motorsport Cup Cables Guard Transmission LSD Urethane Transmission Mount Suspension Ohlins Dampers R&T BBi Street Cup Front Bumpsteer Kit BBi Street Cup Front Billet Lower Control Arm BBi Street Cup Front Adjustable Thrust Arm BBi Street Cup Rear Toe Steer Kit BBi Street Cup Rear Billet Lower Control Arm BBi Street Cup Rear Adjustable Thrust Arm BBi Street Cup Rear Upper Control Arms Brakes Porsche Motorsport Cup Brake Calipers with Titanium Stainless Brake Lines Bremobo Type 5 Front & Type 3 Rear Rotors Race Technologies RE10 brake pads Wheels BBS Motorpsort E88 Tires Toyo R888 Exterior Porsche Motorsport Cup Splitter Interior BBi 997 Street Cup Roll Cage Recaro Pole Position Racing Seats Sabelt Harnesses Radio Delete Last edited by BBiAutosport; 08-11-2015 at 02:59 PM.. |
Engine & Transmission Upgrades
BBi Autosport Coolant Pipe Welds Coolant pipe failure is an inevitable problem with the Porsche GT1-block equipped models (GT3, GT2, Turbo). We offer replacement billet aluminum coolant pipes to be permanently welded as the best preventative fix/solution for this problem. Compared to the factory fittings, the replacement BBi billet fittings offers supeior metallurgy to allow stronger, higher quality welds. ![]() ![]() ![]() BBi StreetCup Side Muffler Deletes ![]() Shedding weight is one of simplest ways to add performance to your Porsche. Unfortunately, reducing weight on the already slim GT3 is rarely an inexpensive task and the factory exhaust system is already very well designed for optimum power delivery. The only drawbacks to the factory system is a muted exhaust note that was designed to comply with the local laws and appeal to a wide customer base, and the excess weight from the muffler packing material. We addressed those flaws when we designed our exhaust system for the 997 GT3. Most other aftermarket exhaust systems on the market replaces the secondary center muffler and the performance gains and weight savings are minimal. The factory secondary exhaust weights approximately 20 pounds and the average secondary muffler bypass weighs approximately 7 pounds, which equates to only 13 pounds of weight savings. We took a more unorthodox approach and bypassed the much heavier primary side mufflers. The primary mufflers are weigh approximately 44 pounds total while our bypass pipes are 4 pounds in comparison. The result is a substantial reduction in weight behind the rear axle which significantly improves handling and less restriction to produce a much more aggressive exhaust note. Key Features - Produces deep aggressive exhaust notes at lowers revs & exotic high pitched exhaust notes at higher revs - T304 stainless tubing - Meticulously TIG welded - Brushed stainless finish - Stainless hardware and clamps - 100% emissions legal - Will not void warranty - Factory secondary mufflers and catalytic converters are all retained - Direct bolt on replacement, - Hand built to Order OEM Mufflers (44lb) vs BBI Side Muffler Bypass (4lb) Comparison ![]() Porsche 997 4.0 GT3 RS Light Weight Flywheel Clutch Kit ![]() Porsche Motorsport Cup Shifter
To improve handling and make this GT3RS even more track-worthy, we installed our complete BBi Street Cup Suspension Package.
Inspired by Porsche’s motorsport program, he Street Cup name represents the culmination of our winning experience in professional motorsports and the extensive R&D efforts with our in-house fabrication, suspension engineering, and engine development programs. All of the experience gained with our successful racing background combined with state-of-the-art materials and the highest quality manufacturing have yielded an upgrade package worthy of the Porsche 911 name. BBi Street Cup Suspension Components Commonly Share The Following Features:
BBi Autosport Front Bump Steer Kit ![]()
BBi Autosport Front & Rear Lower Control Arm Kit ![]()
BBi Autosport Rear Adjustable Toe ![]()
BBi Autosport Front & Rear Thrust Arm ![]()
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit ![]()
BBi Autosport Rear Upper Control Arm Kit ![]()
Beauty Shots of the BBS E88 Wheel
![]() ![]() BBi Porsche 996/997 Street Cup Roll Bar ![]() ![]() Features
