Porsche 997.2 C4S w/ Bose Subwoofer StreetCup Roll Bar Install
![]() ![]() BBi Autosport is proud to present our Porsche 996 & 997 Street Cup Roll Bar. The BBi Street Cup roll bar features a 2 piece design and 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points), and still be compatible with the factory Bose subwoofers. Other similar roll bars on the market are not compatible with the subwoofer. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut. Features
This BBi Autosport Porsche 996 & 997 Street Cup Roll Bar is now available for purchase through Pelican Parts: Pelican Parts - Product Information: BBIROLLBAR9697 Beauty shots of the cage's welds ![]() ![]() ![]() ![]() ![]() ![]() Installation Process ![]()
