BBi Autosport Porsche 991 GT3 StreetCup Roll Bar
BBi Autosport Porsche 991 GT3 Roll Bar
BBi Autosport is proud to present our Porsche 991 Street Cup Roll Bar. The BBi Street Cup roll bar features a 2 piece design and 4130 chrome moly steel tubing (1.625" x 0.095) for excellent strength to weight ratio. With our sensible approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available
- Bolt-in installation requires no drilling and minimal carpet trimming
This BBi Autosport Porsche 991 GT3 Street Cup Roll Bar is now available for purchase through Pelican Parts:
Pelican Parts - Product Information: BBIROLLBAR991II
Beauty shots of the cage's welds
Old 08-16-2015, 05:51 PM
Satin White BBi Street Cup Roll Bar Installed into White Porsche 991 GT3
Old 08-17-2015, 08:19 AM
BBi Porsche 991 GT3 Street Cup Roll Bar with Custom Red Powdercoat Finish
Old 08-18-2015, 03:46 PM
Black Porsche 991 GT3 with Sport Bucket Seats & Black BBi Roll Bar
Old 08-20-2015, 09:29 PM
BBI Porsche 991 GT3 Roll Bar Gloss Blue
Old 08-25-2015, 04:56 PM
Old 09-10-2015, 03:13 PM
BBi Autosport Porsche 991 GT3 StreetCup Roll Bars are now back in stock and ready to be coated.
Old 09-25-2015, 10:52 AM
Sapphire Blue Porsche 991 GT3 BBi Roll Bar Install
Old 04-21-2016, 09:40 PM
BBi Porsche StreetCup Roll Bar installed into a silver 991 GT3 with the Sport Bucket Seats.
Old 01-24-2017, 04:25 PM
