Porsche 997.1 GT3 Street Cup Weekend Track Car Build
Greetings Pelican Forum Members,
We would like to present this clean White Porsche 997.1 GT3 that we recently built. Our client wanted to take it to the track and brought the car to us upon immediately after taking delivery. To ensure safe and reliable operation, we welded the coolant pipes to prevent it from catastrophically failing despite the vehicle's low mileage. Subsequently, we installed our BBi StreetCup Roll Bar, Suspension Components, and many other goodies.
All BBi Autosport products are now available directly through Pelican Parts and we are definitely proud to have established this great partnership! Link to Pelican BBi Autosport Parts Catalog:
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Vehicle Specifications
Engine
  • BBi Billet Coolant Pipes Fittings Welded
Drivetrain
  • OEM Porsche 997.2 GT3RS 4.0 Liter Clutch & Flywheel
  • OS Giken Limited Slip Differential
Suspension
  • KW Hydraulic Lift System 2
  • BBi StreetCup Rear Upper Control Arm Links
  • BBi StreetCup Rear Toe Link
  • BBi StreetCup Competition Corner Balance & Alignment
Exterior
  • XPEL Ultimate Protection Film Complete Front End Wrap (Bumper, Headlights, Hood, Fenders, Mirrors)
Interior
  • BBi StreetCup Bolt-In Roll Cage with Custom Gloss Red Finish
  • Porsche Carbon Fiber GT2 Sport Bucket with Custom Red Stitching
  • Sabelt 6 Point Harness with Aluminum Adjusters, 3-2" Hans Friendly Shoulder Straps, Pull Down Lap Belt Adjustment, Bolt In Mounting
Suspension Upgrades
To improve handling and make this GT3 track-worthy, we installed our complete BBi Street Cup Suspension Package for the rear end. Inspired by Porsche’s motorsport program, he Street Cup name represents the culmination of our winning experience in professional motorsports and the extensive R&D efforts with our in-house fabrication, suspension engineering, and engine development programs. All of the experience gained with our successful racing background combined with state-of-the-art materials and the highest quality manufacturing have yielded an upgrade package worthy of the Porsche 911 name.
BBi Street Cup Suspension Components Commonly Share The Following Features:
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi StreetCup Rear Upper Control Arms
  • Link the rear wheel carrier to the sub-frame.
  • Allow adjustment of track width and kinematic toe.
  • Complete set of 4
  • Provides additional rear toe adjustment
  • OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
  • Each kit includes pair of 2 Links
  • Part Number BBITOE9697REAR
Rear Suspension Installed
Old 08-18-2015, 10:58 AM
KW Suspension Hydraulic Lift System Installed
BBi Street Cup Competition Alignment
Old 08-18-2015, 10:59 AM
Removing Engine for Coolant Pipe Welds and Clutch Replacement
Factory Porsche 4 Liter GT3RS Clutch & OS Giken LSD Installation
Old 08-18-2015, 11:00 AM
Disassemble Engine Top End
Removing OEM Fittings
Coolant pipe failure is an inevitable problem with the Porsche GT1-block equipped models (GT3, GT2, Turbo). Bonded together by adhesives, the factory pipes will eventually fail and be catastrophic. As the best preventative fix/solution for this problem, BBi Autosport offers replacement billet aluminum coolant pipes to be permanently welded that are available through Pelican Parts. Compared to the factory fittings, the replacement BBi billet fittings offers superior metallurgy to allow stronger, higher quality welds.
Coolant Pipes Meticulously TIG Welded
Welded Coolant Pipes
One of the Many Hoses Replaced
Old 08-18-2015, 11:03 AM
Engine Goes Back In
Interior. Custom Red Stitching for GT3 Sport Bucket Seats
BBi 997 StreetCup Roll Bar
Custom Red Powdercoat Finish
The BBi Street Cup roll bar features a 2 piece design and 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points), and still be compatible with the factory Bose subwoofers. Other similar roll bars on the market are not compatible with the subwoofer. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Features
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seat-belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available
  • Bolt-in installation requires no drilling and minimal carpet trimming
This BBi Autosport Porsche 996 & 997 Street Cup Roll Bar is now available for purchase through Pelican Parts:
Pelican Parts - Product Information: BBIROLLBAR9697
Details of Welds
Old 08-18-2015, 11:04 AM
BBi 997 StreetCup Roll Bar Installation
Old 08-18-2015, 11:08 AM
Clear Bra Installation
BBi Autosport now offers clear bra paint protection film installation at our facility.
To protect the most vulnerable areas of your vehicle from damage caused by rocks and other debris on the street and track, we use XPEL's Ultimate Paint Protection Film as it combines best-in-class durability and clarity not previously available in the market.
Our technicians and clear bra installers work together take to extreme care of the vehicle during the installation process. All of the painted surfaces are thoroughly cleaned each before the installation and parts are carefully removed when necessary to help conceal the edges of the film.
Old 08-18-2015, 11:09 AM
Old 08-18-2015, 11:10 AM
