BBi Autosport Porsche 997 & 997 StreetCup Suspension Package
BBi Autosport Porsche 996 & 997 StreetCup Suspension Package
Now Available Through Pelican Parts
(Click on images for higher resolution)
Partnering with Pelican Parts, BBi Autosport is pleased to present our Street Cup Suspension Package to further improve the handling of the Porsche 997 GT3/GT3RS and make it even more track-worthy. With many years invested in development and testing on both the track and street, this complete suspension upgrade package will elevate the driving experience beyond the already impressive factory performance levels.
Inspired by Porsche’s motorsport program, the Street Cup name represents the culmination of our winning experience in professional motorsports and the extensive R&D efforts with our in-house fabrication, suspension engineering, and engine development programs. All of the experience gained with our successful racing background combined with state-of-the-art materials and the highest quality manufacturing have yielded an upgrade package worthy of the Porsche 911 name.
BBi Street Cup Suspension Components Typically Share The Following Features:
  • Hard tested on the street and track
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi Autosport Front & Rear Lower Billet Control Arm Kit
(shown with optional camber and litronic shims)
  • Improved two piece 996 GT3 lower control arm design
  • Stronger than cast motorsport Cup arms
  • Allows proper camber adjustment 996 & 997 Models
  • Uses GT3 shims to adjust camber & lower control arm length (sold separately)
  • High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
  • Sealed monoball inner bearing
  • Allows easy access to inner arm hardware
  • Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
  • A must have for all track and race enthusiast
  • Each kit includes pair of 2 arms
  • Fits both front and rear axles
  • Part Number BBILOWRCNTRL9697
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
  • Part Number BBIBUMP9697FRONT
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
  • Part Number BBITOE9697REAR
BBi Autosport Front & Rear Thrust Arm
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
  • Part Number BBITHRUST9697
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Complete set of 4 (2 front & 2 rear)
  • Part Number BBITHRUSTBUSH9697
BBi Autosport Rear Upper Control Arm Kit
  • Link the rear wheel carrier to the sub-frame.
  • Allow adjustment of track width and kinematic toe.
  • Complete set of 4
  • Part Number BBIDOGBONE9697
About BBi Autosport
Based in Southern California, we are a Porsche tuner and parts manufacturer. BBi Autosport was founded in the summer of 2005 with the mission of bringing artistry and craft to the Porsche tuning industry. We are committed to producing proven performance upgrades that are manufactured to the highest quality standards. With our new bigger facility, new staff and new product catalog this year, we are a one-stop shop and excited to offer everything from race car builds to scheduled factory maintenance.
With over 30 years of combined motorsport history, BBi’s operation is truly unique. Racing traditions run deep here at BBi Autosport. As the company's founder and technical director, Betim Berisha has worked in Racing for many years at prestigious events like the 24 Hours of Lemans and 24 Hours of Daytona. First for Fordhal Motorsport working on their GT3RS and Saleen S7 in ALMS and Grand Am series, Alex Job Racing on their ALMS GT3RSR, J3
Racing working on their GT3RSR and then Porsche Motorsports North America as their dyno tech an supporting Porsche teams at ALMS, Grand Am, Speed World Challenge events. Sharing the same passions, most of BBi's support and shop staff have also previously worked for other motorsport programs. Being a one-stop shop, BBi Autosport is equipped to offer everything from hand-built hard goods to championship-winning GT3 Cup Cars.
For up to date information of current shop activities, projects, and product releases, please follow us on our Facebook and Instagram accounts:
https://www.instagram.com/bbiautosport
https://www.facebook.com/BBiAutosport
Old 09-10-2015, 12:18 AM
Here are some pictures of the suspension components installed on one of our flagship projects
Vehicle
  • BBi Autosport Project Swan Porsche 997 Turbo (GT2 Conversion)
Engine
  • BBi Built 3.8 Liter Flat Six Turbocharged Engine
Suspension
  • JRZ 2 Way Triple Adjustable Motorsport Dampers
  • BBi Custom Spec Swift Springs
  • Tarrett Front Adjustable Sway Bar End Links
  • Tarrett Rear Adjustable Sway Bar End Links
  • BBi StreetCup Front Bump Steer Kit
  • BBi StreetCup Front Adjustable Thrust Arm Kit
  • BBi StreetCup Rear Adjustable Thrust Arm Kit
  • BBi StreetCup Front Billet Lower Control Arm Kit
  • BBi StreetCup Rear Billet Lower Control Arm Kit
  • BBi StreetCup Rear Toe Steer Kit
  • BBi StreetCup Rear Upper Control Arm Kit
  • Porsche Motorsport Front Wheel Carrier
  • Porsche Motorsport Rear Wheel Carrier
  • Porsche Motorsport Cross Member
BBi Porsche 996 997 Street Cup Suspension Upgrades Laid Out:
BBi Rear Suspension Setup:
Front Suspension:
BBi 996 997 Front StreetCup Lower Control Arm Kit, Adjustable Thrust Arm, and Bump Steer Kit
Close up of BBi Street Cup Adjustable Thrust Arm & Lower Control Arm Kit
BBi 996 997 StreetCup Front Lower Control Arm & Tarret Adjustable Sway Bar Endlink
BBi StreetCup Competition Corner Balance & Alignment
Old 09-22-2015, 08:10 AM
Tags
bbi , bbiautosport , streetcup , suspension
