BBi Autosport Porsche 991 Turbo Stage 2 Power Package Now Available
[FONT="Arial"]
BBi Autosport Porsche 991 Turbo Stage 2 Power Package Now Available Through Pelican Parts!!! ![]() BBi Autosport is pleased to announce the release of our Stage 2+ Power Package for the Porsche 991 Turbo and Turbo S models. After more than a year of development and testing with our dedicated technical partners Cobb Tuning and IPD Plenum, BBi Autosport has finally created a bolt-on tuning package that delivers significant performance gains reliably in a straight-forward and easy-to-install package. Cobb Tuning brings a wealth of knowledge with ECU tuning since 1999, and BBi Autosport has been instrumental with helping Cobb Tuning's development for all applications since its first foray into the Porsche market in 2014. In a similar fashion, IPD has been developing patented intake plenum upgrades for Porsche vehicles since 2004 - now covering more than 30 applications distributed worldwide - and continues to share the same facility and technical resources with BBi Autosport to deliver the most innovative Porsche engine upgrades. Combining all of our expertise and engineering capabilities, all components of our BBi Power Package are designed and developed at our facility to work in perfect harmony with each other and deliver reliable and consistent results. This package includes: Cobb Tuning Accessport V3, IPD Plenum, IPD Y-Pipe, and BBi Barcode Exhaust System Cobb Tuning Porsche 991 Turbo Accessport V3 ![]() No performance upgrade is complete without a tune to reliably extract as much power as possible while maintaining excellent drivability and consistent results. The Accessport for the 2014 2015 Porsche 911 Turbo and Turbo S is the ONLY handheld flash option. Being the world's best-selling and most flexible ECU upgrade solution, the Accessport V3 comes with Stage 1 and Stage 2 Off The Shelf maps as well as complete custom tuning capabilities for any modification level. Features Power Gains: Stage 1 increases power throughout the low and mid-range with maximum gains of around 60 whp are seen between 3000-4000 RPM. Low-end torque is increased by over 100 ft./lbs! Stage 2 gains 120 ft./lbs down low and nearly 100 hp. at peak. Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps. Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need. Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway. In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data. Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data. Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU. Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership. Full Uninstall: Using the Uninstall option will completely remove our programming from the cars ECU. It is then able to be re-installed after a dealer visit or on another vehicle. BBi Porsche 991 Turbo Barcode Exhaust ![]() Features: Produces more aggressive exhaust sound Reduces restriction to increase horsepower, torque, and improve throttle response Crossover X-Pipe to balance exhaust from each cylinder bank 304 stainless steel aerospace tubing 3" diameter piping throughout system Meticulously TIG welded Brushed stainless finish Significant weight savings HJS OBD2 compliant 200 cell catalytic converters No CEL (Check Engine Light) Direct bolt on replacement Stylish design with laser etched BBi logo Optional high temperature black ceramic coatings available Handcrafted in the USA For off-road use only IPD Porsche 991 Turbo /S Plenum ![]() The revolutionary and patented design of the IPD Porsche Plenum improves intake air flow by replacing the factory plastic "T" style design with a more efficient, precision casted aluminum "Y" design. The fundamental purpose of a plenum is to deliver smoother air at a higher velocity with greater efficiency. The IPD Plenums distribute the air flow more effectively while reducing pressure drop at the throttle body inlet by utilizing a true merge collector and dimpled interior surfacing. IPD 991 Turbo /S High Flow Y Pipe ![]() To further improve airflow, the innovative IPD High Flow Y-Pipe design is a direct fit OEM replacement that is not only larger but also utilizes non-round runners, in addition to the same design principles as the plenum. These improvements of the Y-Pipe alone delivers an additional 35+ wheel HP, 40+ Foot Pounds of Torque. Together, the IPD Plenum & Y-Pipe increase horsepower and torque well above the factory power curve from launch to redline. The result will be smooth and linear power with considerably quicker boost response creating a longer and more desirable power band. IPD 991 Turbo Plenum & Y-Pipe Features: Increases horsepower, torque, and boost responsibly optimizing air flow efficiency Designed with 3D Modeling & Computational Fluid Dynamics software Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow High quality cast aluminum construction Direct fit OEM replacement Made in USA |
Additional Beauty Shots of the IPD 991 Turbo Y-Pipe & Plenum
IPD 991 Turbo Y-Pipe ![]() ![]() ![]() ![]() ![]() IPD 991 Turbo Plenum ![]() - [email protected] |
