Aftermarket windshield
Hi
Just had my windshield replaced by the same company that does for the Porsche dealer.
Windshield looks fine and fits well, but the bottom edge on the outside, where the rubber strip of the cowl should touch it to prevent water getting into the battery compartment etc, has about an eighth of an inch gap along the length of the windshield except at the outside edges. It's an aftermarket windshield so may have a marginally different bow than OE
Any ideas to fix?
I thought about putting a thin strip of Neoprene under it.
Old 11-11-2015, 02:40 PM
Uncertifiable!!!
Uwon's Avatar
Would be helpful if you could mention your model.
In the 997.1 at least, the molding is held by three screws/nuts-a torx in the centre and a 10 mm plastic nut about 6" from each corner (under a flush plastic cover that slides off). There is some play for adjustment particularly by the nuts. loosen the nuts and screw and shove the molding towards the windshield and re-tighten.
Are you happy with the rubber around the windshield? The aftermarket stuff is crap. The OE rubber is the only way to go.
Hope this helps.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-12-2015, 05:43 AM
Windshield
Thanks,
It's a 997.1 (Carrera S, 2007).
I already adjusted the molding to get the outer edges to fit snug, but there is still a gap of about 1/4" between the windshield and the rubber seal/molding at the bottom of the windshield in the the middle for about 15 - 18 inches.. The installer told me that water does go under the rubber even if it fits snug, but the water is diverted and does not go into the battery box. This evening I will run some water on the windshield to see where it goes. I'll try some more adjustment as well.
The rubber around the windshield is not as good as OE, but doesn't look bad.
Old 11-12-2015, 09:10 AM
