New Member - First Post
Here is the link to my initial post on Rennlist (996 Cranks but doesn't start - Rennlist Discussion Forums) which details the path up to now.
The problem is the car cranks but doesn’t start. This happens randomly and can occur with the car hot, cold, first starting of the day or after several starts with minutes or hours in between running. The cranking cycle is strong and does not spin slowly. The car also stalls when the gas pedal is depressed while accelerating from a standstill and hunts for idle while at stoplights.
I replaced the fuel pump with great anticipation that if would solve my non start problem, but it didn’t. A local Indy suggested this based on the pump behaving similar to a pump losing its prime and the pump had a bad whining sound. Couple of CEL’s finally showed up and I’m hoping they are recognized by someone that has a suggestions or solution. Code P0455 and 446, which could be the canister, vent lines, gas cap, vent valve, or regeneration valve. Gas cap replaced a year ago, vent valve on the filler tube replaced about a year ago as well.
All ideas, thoughts?
Old 12-05-2015, 09:09 AM
A few new engine codes are now present..
P0444 Solenoid valve 2 for carbon canister Open circuit...Can someone point out which valve this is?
P0446 Shutoff valve activated charcoal filter (function) below limit value. Same question, which valve is this.?
Old 12-30-2015, 12:03 PM
01 996 EVAP system woes - Page 2 - Rennlist Discussion Forums
Read post #17. You can check the purge valve by disconnecting it from the intake, plugging the line to the intake and start/run the car. Which is also referenced in the thread.
Old 12-30-2015, 04:26 PM
