4S Tranny removal
Can anyone tell me If I can remove the tranny from man 02 4S without removing it with the engine? Local Porsche /BMW mechanic is telling me they must come out together. Planning to upgrade IMS but I don't want to make it any harder than it has to be.
Old 01-11-2016, 12:31 PM
I can be done. The front drive shaft moves out of the way. You will need to support the rear of the engine. make a support bracket and bolt it to the sway bar mounts. You will also need to tilt the engine down about 2" to reach the 12:00 bolt.
Old 01-11-2016, 12:47 PM
Thank you. I ordered a Benchley's manual and will read it over a few times prior to starting but that sure sounds simpler!
Old 01-11-2016, 01:26 PM
