Black Porsche 997 Carrera BBi StreetCup Roll Bar Install
Black Porsche 997 Carrera Gets BBi StreetCup Roll Bar / Harness Bar Installed
(Click on images for higher resolution)
We took delivery this super clean Black Porsche 997 Carrera , already upgraded with a GT2 style body conversion, and installed our Street Cup Roll Barwith a custom red finish to properly mount harnesses and increase protection. Available through Pelican Parts, our bar features 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points), and still be compatible with the factory Bose subwoofers. Other similar roll bars on the market are not compatible with the subwoofer. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut. Here are some pictures of installation process and additional information that that we would like to share:
BBi Autosport Porsche 996 & 997 Street Cup Roll Bar
Features
  • Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
  • Mounts to front seat belt mounts and rear strut towers
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
  • Designed to work with stock or any aftermarket seats on the market
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available
  • Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3 (excluding cab models)
  • Bolt-in installation requires no drilling and minimal carpet trimming
  • Compatible with models equipped with Bose Sub-woofer
  • Made in USA
Additional Pictures of the Bar Installed
Old 01-15-2016, 08:32 PM
Old 01-15-2016, 08:33 PM
BHP231's Avatar
Looks sensational.
What are those front seats? They also look fantastic.
Thanks.
1971 911T
1985 944 manual road car
1983 944 race spec car
2009 997.2 Carrera PDK) gone but not forgotten)
1988 Carrera Targa Euro Spec (gone by not forgotten)
Old 01-20-2016, 01:01 AM
