help! heating don work on my 996
hi
i am still ice cold
the problem is that the heating system dont work.
a/c cooling is ok
but when I swich to heater (with or without a/c) only cold air comes out.
checked the hot water tubes next to the battery bay - and its cold.
what can be the solution?
many (many!) thanks from a 996 owner in Israel
bitton gal
Old 01-27-2016, 10:52 PM
What does your temp gauge say? Maybe you need a thermostat. Sounds like yours may not be opening. I assume you have coolant in the system?
Tony G
10 Porsches come & gone!
1962 Morgan Plus 4
Old 01-28-2016, 04:16 AM
still cold :)
hey
themostat looks ok.....on cold - it operates fine
on "hot" - the air still comes cold
collant is ok.
tnx
gal
Old 01-28-2016, 04:27 AM
Not the temperature controls inside the car. I'm talking about the thermostat on the engine that circulates water through the cooling system. Is your engine getting warm? When it reaches 180° it's supposed to open in send water to the radiator and bring in cooler water etc. that's where your heating system obtains the heat for the cabin.
Tony G
1962 Morgan Plus 4
Old 01-28-2016, 04:39 AM
Tony G
1962 Morgan Plus 4
Old 01-28-2016, 06:01 AM
Originally Posted by tonythetarga View Post
hey tony
i am not sure now. can i write to your personal email?
thanks
Old 01-28-2016, 08:03 AM
and - yes - engine is getting very hot....
but only cold air gets into the car...in the summer its ok...but now i am freezing !
Old 01-28-2016, 08:05 AM
Thermostat for sure. Sounds like it isn't opening. PM me if you want to chat offline.
Tony G
1962 Morgan Plus 4
Old 01-28-2016, 08:17 AM
If you're not circulating to the rad then you can overheat the engine and damage the heads. This needs attention right away.
Tony G
1962 Morgan Plus 4
Old 01-28-2016, 08:18 AM
How many miles on the car? Could also be a water pump failure. The vanes are plastic and have a life span of about 60,000 miles. After that they can break apart and send bits into the engine. If coolant isn't circulating, it's not good.
Tony G
1962 Morgan Plus 4
Old 01-29-2016, 08:14 AM
Tags
heating system
