02 996 IMS questions
I'm about to replace the IMS with an LN unit in my 02 C4S. Bought LN tools. Read lots of literature from different sources but I am confused, Do I really need to pull all 4 cam plugs if I am using the LN tool? Which chain tensioners do I need to loosen. Seems to me I need to only remove the plugs from the driver side rear end (closest to rear bumper) of cyls 1-3 and install the tool designed for 3 chain engines while locked in at TDC and loosen the one tensioner, Is this correct?
Which tool is considered the LN easy out? Nothing looks like any easyout I have ever use. What is the little threaded nut like thing with the wire attached to used for? |
Did they come with instructions? If so, follow them to the letter.
I have not ordered the bearing yet as I want to be positive it is a single vs dual race prior to purchasing a new one. Was told by the supplier instructions are not provided but I have gone on LN's site and was able to download them. Its not clearly indicated which cams to lock nor which chain tensioners need to be loosened.
http://lnengineering.com/files/IMSR-Instruction-Warranty.pdf
