ims "solution"
Don't want to start a dust-up on the IMS choices, but would like to hear from someone who paid the big money and got the LN "Solution" IF the direct oil feed was to become blocked, will the bearing survive? I believe that the bearing is semi submerged in engine oil even without the oil coming from the direct line.
Old 02-24-2016, 04:18 PM
The bearing is coated, and has been run without oil and did not fail. I think the parameters of the test may be on the FSI web site. It does use filtered oil so the chance of clogging is slim. Also the feed line is held close to the engine block so it getting damaged is also slim, and if it does you probably have other things to worry about.
Old 02-24-2016, 05:02 PM
A little abashed to ask, but what is FSI?
Old 02-25-2016, 03:22 PM
Flat Six Innovations
Sent from my Nexus 6 using Tapatalk
Old 02-25-2016, 03:29 PM
I am leaning towards the IMS Solution over the "regular" IMS kit. If my engine can pass the pre-install inspection that is.
Old 03-20-2016, 06:14 AM
Just had the "solution" installed by Justin at South Shore Autoworks, in Kingston, Mass. Great shop, very clean work. After reading about the bearing issue ad nauseum, the plain bearing makes the most engineering sense to me.
Old 03-20-2016, 04:30 PM
And because of its permanent nature, it also can add substantial value at resale.
Old 03-21-2016, 03:33 AM
Evil Genius
Rusty Heap's Avatar
alternatives to LN price points.
slick design, direct oil feed.
http://tunersmotorsports.com/trs-development/ims-bearing-direct-oil-feed/
Life is a big ocean to swim in.
Wag more, bark less.
Old 03-22-2016, 09:05 AM
Sorry, but that retrofit is not even remotely an alternative the IMS Solution at any price point.
Old 03-22-2016, 09:26 AM
Steady fella's, the job is already done
Old 03-22-2016, 04:01 PM
