UCF (guest)
Guest
Posts: n/a
Hi, I have a 997.2 Cabrio and the headliner is separated from the convertible top with a loose strap. this is on both sides, will that be the only part that needs to be glued? how can i make sure i am reaching all the inner lining without dismantling to reconnect to the outer fabric? I also have a warranty but apparently this is not covered.is that so?
thank you
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Common Convertible Top Problem Repair - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Old 04-01-2016, 01:52 PM
Nick at Pelican Parts's Avatar
Not sure rte-gluing will do it. Likely needs to be replaced.
- Nick
