C4 Adjustable Control Arms?
2002 C4 with Vogtland performance springs and Bilstein Sport shocks. New front tires were scuffed off [inside] after 5,000 miles. These were new tires and an alignment and steering angle sensor calibration were performed upon completion of installation of springs and shocks. Put new tires on and had a new alignment to take out as much camber as possible. Only 2% was the limit they were able to take out, so the problem will still exist [I think].
I have not been able to find adjustable control arms for a 2002 C4. Anyone out there know of any? If not, I will have to put the original springs and new shocks on.
Thanks!
Old 04-28-2016, 09:08 AM
What is the toe setting? Toe will wear the tires faster then camber.
Old 04-28-2016, 09:11 AM
dporto's Avatar
Also may need bump-steer kit if you can't get it back into spec. The lowering springs change the geometry of the tie rods...
Old 04-28-2016, 11:42 AM
Administrator
Luccia at Pelican Parts's Avatar
Rennline makes adjustable control arms for your 996 HERE. There are also a few other brands HERE.
Old 04-28-2016, 12:46 PM
Thank you all!
What I am concerned about now is how far will I have to go?!
I am really considering putting the original springs back in. If I do put the original springs back in, will the Bilstein Sport shocks have to come out too?
Old 04-30-2016, 09:54 AM
You should be able to keep the sport Bilsteins no problem. Put many of those on cars with stock springs.
Old 05-04-2016, 02:35 PM
