Won't go in reverse and losing all gears.
I rebuilt my engine and replaced the clutch. Now I think the linkage is messed up because I had all gears but reverse. Then 2/4/6 no just 2??? Someone please help me. Also the engine was running great now there is a bunch of misfires after putting 50 miles on it? Thoughts?
Old 05-23-2016, 08:37 AM
jwetering's Avatar
Your cables have popped off at the transmision probably.... assuming you set up the shifter correctly. The clips there aren't great.
As far as your engine troubles go, I would talk to the man who "rebuilt" your motor. Your post does not have the tone of a DIY engine builder, so I am assuming it wasn't you.
If it was then you're going to have to go back through what you did. Cam timing would be a good start.
What was wrong with the engine that caused you to rebuild it? How well was it running for those first 50 miles?
jasper
Old 05-23-2016, 10:04 AM
