jfort's Avatar
radar detector mounting
07 997 C2S. I want to mount a window sticking radar detector new the rear view mirror. I have a direct power cord to run around the windshield. Where is the best place to tap into 12V and ground? Is there an opportunity for switched 12V in the overhead light/sunroof panel?
Jeff Fort, Findlay, Ohio
70 914-6 2.7
07 Carrera C2S
05 Cayenne V6
Old 06-02-2016, 08:19 AM
Hunt3R's Avatar
Run it down behind the drivers side pillar to the fuse box and get a fuse tap so you can plug it in to an open fuse slot that has switched 12V power, although I dont recall offhand which fuse slot that is but you should be able to figure it out from the fuse map. This is what I did with my escort. I had found an installation guide with all the details on one of those other Porsche forums in the 997 section. It was pretty easy and works great. Switches on and off with the car ignition.
Old 06-03-2016, 05:45 PM
